hello they are The MomiX
TheMomiX 2006/12/16 10:12:13
I am Italian…
excused probably are off-topic
I run in the category top class miniums 4wd tamiya Italy
this is my miniums…mini 4wd
you would help for it appeal to with the batteries
me I use batteries size AA intellect 2000mha or kan battery 1800mha
thanks and hope in one aid
hello the momix
www.giocoestudio.com
these miniums are composed of frp tamiya
every piece are derived from tamiya
not are null of constructed car
are all material tamiya
we run with motors from 32.000
234metri for 3 turns medium better time 30,44
we notice that there are 4 bridges jump [此贴子已经被作者于2006-12-16 10:37:30编辑过]
guoqingyun 2006/12/16 11:04:56
cool~~~~~~!想不到还有来自意大利的车友!!!
帅~!
my english is bad!
haha...your car is cool~!
how much is it??
南健 2006/12/16 11:21:33
glad to see an italian friend~
and...I don`t good at english
in china we don`t play tamiya mini4wd, because tamiya don`t make any race in china...
this time in china, many racer love "unlimited race"
I don`t have test that two kind of batterys, sorry to I can`t help for you.
your machine is work of art~
胜龙 2006/12/16 12:08:50
I can't understand the picture one.
Why do you make a car like this?
It's unusual.
Can you tell me some about it?
[此贴子已经被作者于2006-12-16 12:38:58编辑过]
南健 2006/12/16 12:27:22
unsymmetry framework is helpful run bridge
胜龙 2006/12/16 12:33:07
4 brigde is difficult
gaofanjack 2006/12/16 13:35:03
oh my god........u r crazy
天才的祈祷 2006/12/16 14:26:48
hello they are The MomiX你们好,以下的图都是Momix
I am Italian…我来自意大利
excused probably are off-topic请原谅这可能是题外话
this is my miniums…mini 4wd 我们在意大利玩比较高等级的mini4wd, 这是我的四驱车
you would help for it appeal to with the batteries 需要你们大力帮助的地方是在电池上
me I use batteries size AA intellect 2000mha or kan(凯恩) battery 1800mha我通常使用intellect(精英)2000毫安时和kan1800毫安时的5号电池
thanks and hope in one aid谢谢,请多多指教!
这些四驱车基本都是由tamiya零配件组装的
每一个部件几乎都是
not are null of constructed car没有其他无效的部件
是全tamiya材料车
we run with motors from 32.000我们使用32000转的马达
234metri for 3 turns medium better time 30,44 234米的跑道跑三圈,最好成绩30秒44
we notice that there are 4 bridges jump 我们可以看到有4个跳桥
由于momix是意大利人,所以难免会有些许错误:metri应该是metre解释为"米" 是有满多语法错误,没关系,我尝试着翻译了
[此贴子已经被作者于2006-12-16 15:13:03编辑过]
追风箭 2006/12/16 16:45:29
the car is so beautiful who can answer to me what's the matter this car why it not fast
玩车的乐趣 2006/12/16 18:33:43
我不会英语啊.? 他们的车有多少节呢>? 我去了他们的网站看了看.!
TheMomiX 2006/12/16 18:43:44
we are not fast because of the difficulty of the bridges
in more we are limitaty to use only motor tamiya and Ncdi batteries or mimh we cannot use lipo
was turned towards right
you that used batteries?
which are best second you!?
here my loaders!
my MSN: themomix85@hotmail.it
broblem fotos sorry
have been distributed in Italy;
2) Admitted reciprocations:
- All are admitted and single reciprocations TAMIYA originate them for the Mini4wd, Mini4wd FOR, Dangun Racer, MiniRC, MiniF1 that has been distributed in Italy;
- Receiving of the miniRC cannot be used.
3) Traction:
- The models must always run with the 4 drive wheels;
4) Modifications:
- The chassis and the reciprocations can be pierce to you, it folds to you, limati, it cuts to you and it glue to you in the respect of the measures,
- the accessories can be mount to you andor modified in any case provided that they do not damage the track,
- all the materials use you must derive from kit of Mini4wd, Mini4wd FOR, Dangun Racer, MiniRC and MiniF1,
- and prohibited the adhesive abuse for the car construction of accessories;
5) Motors:
- The motors must be originate them TAMIYA,
- They cannot open or be modified and they must be recognizable,
- The pinion motors “double” can be use you single on Mini4wd chassis For,
- all the motors are admitted;
6) Rubbers:
- The rubbers can be modified or tornite,
- the rubbers modifications do not have to damage the track,
- the modified rubbers must however respect the measures of point 12);
7) Mechanics:
- Every part of the mechanics can be modified,
- It is not possible to modify the chassis exposing the gears or parts of they
- the number of the teeth of the gears cannot have varied,
- Position cannot have varied the transmission relationship changing, order or connection of the gears;
- it is possible to use specific liquids for the maintenance electrical worker and mechanics of the model;
8) Small wheels guide:
- E' possible to use whichever type of small wheel guides commercialized from Tamiya Italy in order to make to slide the model on the sides,
- the roller metallic from 17mm and 19mm they always must be equips you with O-Ring in rubber or plastic;
- the roller are admitted to semisphere in metal (art. 15342), but they must be mounts to you integral;
- Every roller type “hourglass” (art. 94329) it is from conteggiare like a single one roller.
9) Feeding:
- The batteries must be two stilo AA max 1,5Vcc, very fixed to the model in I affixed spaces to you.
- batteries are admitted: Alkaline, NiCd and NiMh with the covering originate them that of filler the characteristics,
- Batteries to Lithium are not admitted;
10) Auto bodies:
- The cars always must be equipped of auto body, very fixed to the chassis.
- the auto bodies I can be limate, cut and pierced but must at least cover the batteries of the car.
- the eventual modifications do not have pregiudicare the acknowledgment of the model originate them of auto body,
- the Mechanical auto bodies must be mounted for entire,
- the auto bodies in acetate must be painted;
11) Several:
11.1) During the march of the model only the small wheels and the stabilizers to sphere can touch the sides of the track;
11.2) And' prohibited any structural modification and of such assembly to modify in whichever way the surface to contact with the walls of the track regarding that one it originates them Tamiya.
11.3) During the march of the model only the wheels, the vertical brake and small wheels can touch the bottom of the track, nobody other part of the model must touch the deep track;
11.4) For the realization of autocostruiti brakes exclusively is admitted uses it of rubbers coming from black stocks from the box it of assembly;
12) MEASURES:
The measures are reported to the vertical and horizontal axis of the model, the height from earth will come measured along all the model:
- The maximum Width (included small wheels): 105 milimeter
- The maximum height (included ailerons): 70 milimeter
- The maximum length (included front and posterior bumper and small wheels): 165 milimeter
- Minimal height from earth: 1 milimeter
- Wheels (mounted on the Rim): diameter from 22 to 35 milimeter width from 8 to 26 milimeter
- the minimal Weight (ready to run) with batteries: 90 gr
- Small wheels (comprised the “the vertical spheres” of the stabilizers and small wheels): maximum 8
used this translator can be of aid:
http://www.worldlingo.com/products_services/worldlingo_translator.HTML
http://www.worldlingo.com/products_services/worldlingo_translator.htm
[此贴子已经被作者于2006-12-17 2:45:47编辑过]
天才的祈祷 2006/12/16 23:23:11
沟通太困难,我去找我意大利语的兄弟,让他帮忙算了
TheMomix:
I can't understand what you say in your sentences
speak English please then we'll help you
BBQ 2006/12/17 10:31:40
小花看来真的消失了,他看到这个贴子肯定会出来露一下英语水平的
guoqingyun 2006/12/17 11:28:04
这是他发的2个翻译的网站。。大家可以去译译看
这内容太深奥了。。。。估计他是个修汽车的。。。连国家汽车模型协会都搞出来了。。。简直无语。。。。。
这帖子大概只有老徐这样的高手才能看懂吧
胜龙 2006/12/17 12:17:56
I am sorry.But I can't use your translate website because it has mistake.
四害千足 2006/12/17 12:58:11
该论坛豆芽菜最多的一贴......汗
胜龙 2006/12/17 13:01:28
他大概是在说他那边的规则.
要全部用田宫配件
电池只能用:缄性\镍氢\镍镉,不能用锂电池
-最大宽度(包括导轮):105毫米
最高高度(包括副翼):70毫米
165 最大长度(包括前保险杠及导轮前后):165毫米
最小距地球高度:1毫米
车轮(安装在辋):1月22日至35毫米,直径从8至26毫米宽
最小重量(准备办)电池:90克
冰之梦 2006/12/17 20:16:39
不知这个234米是一圈是234米?还是三圈是234米?
如果一圈是234米的话,跑三圈,照以上那个时间跑完,这车都有50节以上了!
如果三圈是234米的话,那车也只能在17节左右,还要加油!
老徐 2006/12/18 8:42:51
引用冰之梦在2006-12-17 20:16:39的发言:
你的计算才能很充分,可惜你忘了别人是在过立交桥情况下.......
天行者sky 2006/12/18 11:01:53
我觉得从这辆车的重量来看上50节不太可能吧,况且是在过四个立交桥的情况下.
受到立交桥的限制速度太快反而得不偿失,应该是17节左右.
萧泰旺 2006/12/18 11:05:47
这帖子太深奥了
全是英文 我可看不懂
萧泰旺 2006/12/18 11:15:09
真没想到四驱车在外国也这么受欢迎
» 发表对本话题的回复,请用图形模式浏览: hello they are The MomiX
